Engine Performance Modifications Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here
engine swap, is it compatible?
Old Jan 13, 2009
1stgearlow's Avatar
1stgearlow is an unknown quantity at this point
i picked up a 92 civic si hatchback, it has a very tired 1.5l in it, but the body is mint. i have a 94 civic si coupe sittin in the yard with a 1.6 sohc vtec but the body is in rough shape. would it work to swap this into the 92? or how hard would it be. or should i even bother?
thanks,
bri
Old Feb 5, 2009
Magicbum's Avatar
Magicbum is an unknown quantity at this point
Post Re: engine swap, is it compatible?
The motor mounts are the same, oil pump is too. I have done some searching in some of the auto parts stores, as long as the cars are 92-95. The 1.6L will bolt right in the other civic. You will also have to use the Engine Computer form the 1.6L in your 1.5L but if one is auto and the other manual then you will need another PC. But if both are auto/ or manual then you should have no problems.
RicoSuave
May 20, 2015 01:57 AM
cloudguy
Apr 28, 2015 05:02 AM
MyOtherRideIsBritney
Jan 20, 2002 03:16 PM
robbclark1
Dec 12, 2001 12:18 PM
supercivic01
South
Nov 30, 2001 11:27 AM
