Engine Performance Modifications Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here
Yo..Noob Here
Old Jun 15, 2006
PR93's Avatar
PR93 is an unknown quantity at this point
Yo..Noob Here
Hey whats up. Thought I decide to join, Dont know much about cars,but imports have always caught my eye, have some questions regarding a 93 civic LX I just bought.
Question: Does my 93 LX have a V-Tech.. reason I am asking because its like a 20hp difference if it is not, I am not able to tell..
And I dont want to do a swap, because I bought the car with 88,100 miles on it so the engine is fairly clean, and dont have too much money to put in a turbo, and I dont want to spray..
Any suggestion will be great.
Old Jun 15, 2006
Shishpanik's Avatar
Shishpanik is an unknown quantity at this point
Your engine is a d15b7, non vtec.
Old Jun 16, 2006
PR93's Avatar
any one else have anything to offer, if its a non v-tec then what options do i have
Old Jun 16, 2006
GoneIn60's Avatar
GoneIn60 is an unknown quantity at this point
you can do basic mods mainly being the bolt ons (intake, exhaust, headers, etc.)
Old Jun 17, 2006
Shishpanik's Avatar
I think you can put a d16y8 head on it. That should boost up the HP. And you don't need VTEC to go fast, it's a common misconception that only vtec hondas are fast. But other than that go with boltons and maybe some aftermarket rims and grippy tires which should help boost go and show.
Old Jun 19, 2006
PR93's Avatar
will changing my head affect my mileage?
Old Jun 19, 2006
Shishpanik's Avatar
I don't think it will change it significantly, since the displacement will remain the same. Even if it does, a catback exhaust system and cold air intake will counter it and give you better gas mileage. Also, you should look into buying a good head gasket (probably from hondata). Most people dont even consider it but it can give you up to 10 extra ponies for around 50 dollars.
Old Jun 19, 2006
PR93's Avatar
Man I really appreciate your help,so if I find a d16y8, all i need is the head and changed the head gaskets, is that all I need to do..
Old Jun 19, 2006
Shishpanik's Avatar
Yeah, or you can use a d16z6 head. Different people say either z6 or y8 is better, i suggest you research it, but with either one, you'll probably be happy with it. Besides the actual engine work you can get a race header/cold air intake/exhaust. Those will add up to 1k + dollars but you'll notice significant gains. I suggest you go Here because alot of people on their have built their d-series from the ground up. They'll be very helpful.
