1993 4 Door LX - suspension bushings
Old 02-23-2014
ngm
ngm's Avatar
ngm is an unknown quantity at this point
Greetings, I just swapped all the bushings on my 350K Civic a few months ago with stock rubber replacements. Now they're squeaking. Can these be lubed without removing them and pressing them back in? Would spraying them liberally with lithium grease spray be a good idea?.
Thanks
Nigel
Old 02-23-2014
Re: 1993 4 Door LX - suspension bushings
Were the rubber bushings neutralized upon installation? Failing to do so can overstress the bushings by keeping them twisted and in a bind.
Read this link about it http://honda-tech.com/showpost.php?p...3&postcount=16
Do a little checking, make sure that Lithium grease is compatible with rubber and will not cause premature failure due to swelling and rot.(I think it is ok but I'm not positive)
Silicone grease and spray is ok to lube with IMO, as far as I know it will not damage rubber.
Also, 350k and 21 years? You sure the car isn't simply complaining about old age?
mokkush
07-14-2015 04:05 PM
krazykoncepts
07-14-2015 01:55 PM
fordover
07-11-2015 09:10 PM
ballmich
07-09-2015 11:59 AM
Spanky4269
07-05-2015 09:40 PM
Quick Reply: 1993 4 Door LX - suspension bushings
