Quick strut install help
Old Oct 18, 2011
Meanie's Avatar
Meanie is an unknown quantity at this point
I plan to install all four strut assemblies on my '93 Civic CX Hatchback. Can anyone provide tips, tricks or suggestions to make this an easy or easier install.
Thank you
Old Oct 18, 2011
MindBomber's Avatar
Live for the Twisties
Re: Quick strut install help
Soak all the bolts in pb blaster each day for a week before doing the job, have a blow torch and potentially a candle to melt wax onto seized bolts ready, good luck.
Old Oct 18, 2011
Meanie's Avatar
Can you elaborate how melted wax will aid seized bolts and the purpose of soaking bolts in PB for a week?
Old Oct 18, 2011
MindBomber's Avatar
The more time you give penetrating lube to work, the better results you will have. I always repeatedly spray bolts that I know will be seized for a few days prior to the job.
Here's a youtube video of the candle wax trick, it works very well.
[autostream]http://autostream.com/ibcivicforums/?page_type=firebirdplayerthumbnail&framepage=1075& transactionid=1318982977-174169168&posted_by=MindBomber_www.civicforums.com &youtube_video_id=KwKHSvKfnHI[/autostream]
Old Oct 19, 2011
Meanie's Avatar
http://www.youtube.com/watch?v=KwKHSvKfnHI
Looks great.
I'll keep that ready in case I have that problem.
Thank you.
BTW, will I need to compress the springs for removal/install of the assembly? How easy will it be to get them out?
Thank you
Old Oct 19, 2011
MindBomber's Avatar
It seems a bit strange at first, but it really does work well, it's a good standby trick. The bolts you really need to be careful with are those going through a metal collar in a bushing, if the bolts seize to the collar they basically need to be cut out with a hack saw.
Yes, rent a spring compressor; if your in the states autozone has a good rental program, in Canada canadian tire does.
If your referring to physically removing them after all the bolts are removed, it's not to difficult. Re-installing is actually the difficult part, but even that isn't terrible if you take your time and have a second set of hands available.
Old Oct 29, 2011
Meanie's Avatar
Thanks for the advice, MB. As you stated, they are seized. Fortunately, I have an impact driver to use which helped tremendously. Using the driver, torch, some PB blaster and wax, I was able to remove the nut on one side. Unfortunately, that's all I could remove as the rest of the bolt is spinning with the bushing. I purchased new bolts, but did not purchase new bushings, until now, after the fact. Thus, the project will be on hold until the bushings come in Tuesday.
I originally thought the entire lower arm and bushing were one and didn't realize I could purchase the bushings separate. The thought of purchasing another lower arm was shivering since I didn't want to spend the money for two of them. After viewing the parts diagram and realizing I could get the bushings separate, I was relieved. When the new bushings arrive, I won't even bother with the impact driver and will simply cut the bolt off with my Metabo and reinstall the new bushings and new bolts.
I have much anti-seize and plan to use it all if necessary during the install.
Thanks again for the advice. It helped me prepare for the task.
Old Oct 29, 2011
lazlong's Avatar
FYI: The bushings need to be pressed in. If you don't have a press go to your local mechanic and have him press them. It'll be cheaper than you think and they can usually do it while you wait. Or you can buy a press and do it yourself but, if you haven't used a press before I wouldn't suggest it unless you have extra bushings and arms 'cause it's really easy to screw it up. I've got this one: http://www.harborfreight.com/6-ton-a...ress-1666.html
Old Oct 29, 2011
Meanie's Avatar
Will that require the need to remove the lower arm or can they do it while on the car? But, if they can do it while on the car, I would need to have removed the strut/spring in which I couldn't drive the car to them.
This is starting to give me a major headache.
Old Oct 29, 2011
MindBomber's Avatar
You need to do it off the car.
This is a pretty common problem unfortunately..
Old Oct 30, 2011
Meanie's Avatar
I'm going to try my hand with a portable bearing/bushing press and hope I can do it on the car. It's similar to a C-clamp but with several size dies to fit the bearing/bushing. I have no desire to fight with the other two bolts to remove the lower arm. If the strut bolt is seized, chances are, so are they.
MN-02-CivicEx
Jun 25, 2015 08:32 PM
Nalmonte
Suspension
Jun 9, 2015 07:08 PM
HitlistCivic01
Nov 28, 2001 10:07 PM
HitlistCivic01
Nov 27, 2001 01:09 AM
MooCoW
Nov 9, 2001 05:22 PM
