beasley
Old May 20, 2013
beasley2013's Avatar
beasley2013 is an unknown quantity at this point
Smile beasley
Have checked post & not seen my problem description. 88 Civic LX. The LH side marker light will blink when RH signal is on. Works fine in LH signal position. All other lights work normally. Have checked the bulbs & even swapped out the turn signal switch for one that is know good. Signal relay works or they wouldn't flash at all or have different speeds. Anybody come across this unusual lighting problem?
