Strange Alternator colors
Old May 4, 2012
Hornet's Avatar
Hornet is an unknown quantity at this point
I have some strange wire colors for the alternator here is what i am looking at -
on car - White/Blue - White/Yellow - Blue - Black/Yellow
on alternator - Red - Blue - White/Blue <-- I know this is a JDM OBD0 alt so what i did was I snagged a USDM OBD0 plug which have the colors White/Blue - White/Yellow - Yellow - Black/ Yellow to help me get an idea of what the wires might be
Here is how I hooked the alt up -- using the USDM plug I matched up all the colors then just hooked the yellow to the blue
But yet im still not showing any charge coming from the alt -- if everyone thinks this might be the correct way to hook it up then I will look further into the alt being bad -- I dont get any battery lights or CEL lights. Could there be a fuse bad? Im thinking possible 12 -15 or 24 under dash.
Am I on the right track??? Thoughts or suggestions!
This is a 92 Civic Si with a 91 B16a that is used as an Outlaw Hornet dirt track car. I am running a P28 - GSR Distributor - Y8 injectors
