95 civic ex, passenger side power window problems
Old Aug 9, 2009
shanek91's Avatar
shanek91 is an unknown quantity at this point
Im new here
passenger window wont roll up
anyone know of how i can fix this?
i've checked the fuses
i dont wanna take the door panel off yet
if i need to, then i need to know what to do
im mechanically inclined so you dont have to use small words with me lol
but please help me out i'd greatly appreciate it
Old Oct 15, 2009
5thGenvtec's Avatar
5thGenvtec is an unknown quantity at this point
Re: 95 civic ex, passenger side power window problems
Well I have the same problem on my 99 si(EX). I replaced switches, and motor/regulator and ended up with the same problem so someone advised me to apply power directly but nothing happened. Anyway, I applied voltage to one wire and ground to the other and I achieved up and down movement by switching positive/negative connection. So my conclusion is that the problem is with the ground connection and this is supplied by the harness coming into the door. Hope this helps
Old Aug 11, 2010
dirthawg's Avatar
dirthawg is an unknown quantity at this point
Whats the best way to correct the problem?
Old Aug 11, 2010
jsmithe2010's Avatar
jsmithe2010 is an unknown quantity at this point
U mean like the cheap way, lasts 3 months, or the expensive way, lasts forever?
Well in order to know what to fix, first u gotta find what the problem is. The "best way" to find what the prob is typically is to troubleshoot the obvious/easy to swap/inexpensive-$0 items. then if that doesn't work, proceed with the harder stuff.
First thing I'd do is to take out the switch and put an ohmeter on it. No ohmeter? swap it out with another switch that's known to be good.
Old Aug 12, 2010
lazlong's Avatar
1. Disconnect window motor connector.
2. Apply positive to one terminal of the motor and negative to the other. I usually use jumper wires and my cordless drill battery.
This will tell you if the if the motor is good or not. Then I would check the switch like jsmithe2010 said.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
bsmiley
Apr 27, 2015 01:27 PM
mwwhonda
Nov 7, 2001 07:24 PM
LexBoy
Nov 5, 2001 08:00 PM
ImmortalEX
Oct 31, 2001 10:00 PM
