sub "pops" when changing tracks, inputs, etc
Old Jan 2, 2009
sweetbrett's Avatar
sweetbrett is an unknown quantity at this point
so here's the basic problem: my newly installed powered sub "pops" almost whenever I do anything on the head unit like change a cd track, change the input, or turn the car off
I got an infinity basslink powered sub and just installed it. This is the first time i've done an amp/sub install myself so I don't know if this is specific to the basslink, my head unit, or what. I did a line level install, running line outputs from my Aiwa CDC-X504MP head unit. and I ran a remote turn on line also. I noticed that whoever installed the head unit (best buy I believe) connected both the AMP REMOTE and ANTENNA REMOTE lines together in 1 spot on the wireing harness. So when I ran my remote power line to the sub/amp, I have both "amp remote" and "antenna remote" connected to it, which I believe if the culprit but I want confirmation from you guys. could it be something else?
Old Jan 3, 2009
sweetbrett's Avatar
Re: sub "pops" when changing tracks, inputs, etc
i went back behind the head unit and disconnected the "antenna remote" line so only the "amp remote" line goes back to the amp/sub now. But, that did not fix the problem. I still get the loud "thump" or "pop" whenever I change tracks, inputs, turn the volume all the way down to 0, and when I turn the car off. I do not get any pops when I turn the car on. When I turn the car off, i get one or 2 pops right away, then about 10-15 seconds later there is another pop.
So now i'm sort of clueless as to what the cause can be. To ground the amp, I scraped the paint off the body around the bolt that holds the side seat cushion down and put the ground there between the plastic and the car body. Could my ground not be good enough? That's the only other piece of wiring that I can think might be causing the problem. Any ideas?
Old Jan 3, 2009
sweetbrett's Avatar
redid the ground wire; reran the amp remote power line....same deal. anyone?
Old Jan 3, 2009
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
Honestly I think the problem is the head unit.
Old Jan 3, 2009
sweetbrett's Avatar
I'm thinkings it's the head unit now too. If i unplug the RCA cables and leave all the other cables plugged in (bettery power, amp remote, ground) i get no pops. I can then plug an mp3 player directly to the sub, with the car on and play music thru the sub with no problems. I also noticed that as soon as I unplug the RCA cables, the power light on the powered sub turns off. I had the "auto turn on" set to off with the mp3 player plugged in and playing. the power light was off and no sound was coming out but then i turned the car on and the power light came on and sound came out (normal operation).
I noticed that if I turn the car off with the RCA cables from the head unit unplugged, the power light on the sub turns off. If i then plug in the rca cables from the head unit (car still off), as soon as I plug either rca line in to either Right input on the sub, the power light will turn on and eventually the Servo light will light solid. If i then unplug the rca cable again, everything will turn off.
so is the head unit not grounded properly? Is the head unit bad?
Old Jan 3, 2009
Possibly a ground issue. Try re-grounding. Head unit could be bad as well.
Old Jan 3, 2009
sweetbrett's Avatar
i ran the ground on the head unit to a bolt but it didn't fix the problem. anything else to try or does this mean the head unit is bad?
Old Jan 3, 2009
I'd say 95% likely bad head unit at this point with really no other ideas what the problem would be.
Old Jan 3, 2009
aznprid214's Avatar
aznprid214 has a spectacular aura aboutaznprid214 has a spectacular aura about
my friend had the same issue.. some head units do this. when he changed the head unit, it solved the problem... only way i can think of is to have maybe the sub amp on a toggle switch to delay power... but rather than that, it is the head unit.
Old Jan 3, 2009
sweetbrett's Avatar
well, i bought a new head unit and installed it. i get the same thumps and the same power/servo lights when the car is off. I have absolutely no idea what the problem is.
Old Jan 4, 2009
Hmm, that really surprises me. You mentioned re-grounding the amp. Tell me more about that, a picture would be especially helpful.
Old Jan 5, 2009
electric130's Avatar
is it the same brand/model of head unit? or another brand/model?
Old Jan 7, 2009
sweetbrett's Avatar
new head unit was a Pioneer DEH-P4000UB
edit: also, i tried 2 other ground points in the back seat area and resanded the original ground point, but neither caused a difference. I also noticed that the sub/amp acted the same even if I didn't have the ground connected.
Old Jan 7, 2009
only thing left really is the amp.
Old Jan 7, 2009
civicplaya's Avatar
civicplaya will become famous soon enoughcivicplaya will become famous soon enough
I'm not to clear on what you're saying... but does the amp, headunit turn off when you turn the car off?... they should, that's what your remote lines do. A good ground spot can be under a nut or bolt somewhere in the trunk, or if you have a bolt for your spare tire, in there, the hole that holds your tire down.
Old Jan 7, 2009
if he drilled a new hole and sanded down the paint, a ground doesn't get much better than that.
Old Jan 8, 2009
sweetbrett's Avatar
If i disconnect the RCAs that run from the head unit then the amp will turn on and off with the car as it is supposed to. So if I leave the RCAs fom the head unit disconnected and connect an MP3 player directly to the amp/sub using a 1/8" male to RCA male cable the sub/amp works perfectly fine. With the mp3 player connected to the rca inputs, I will have to turn the car on to turn on the sub even if i have "auto on" turned on (because the auto on detects signal over the speaker inputs, which I am not using). With the mp3 player connected, I get no thumps even if I push buttons on the head unit and no thumps when the car turns off.
Old Jan 8, 2009
try using a different set of RCA's between the head unit and amp. the RCA's could be pinched or shorted to ground somewhere.
Old Jan 12, 2009
sweetbrett's Avatar
I finally found some time to check the RCA cable out. It was pinched under one of the trim panels. I feel like such an idiot for not checking that sooner. oh well, lesson learned.
Old Jan 12, 2009
sweet! what do i win?
Old Jan 12, 2009
sweetbrett's Avatar
woops, false alarm. so at lunch today i thought I figured it all out but I didn't go 100% because of time. So with the wire still run in it's original location, I connected an mp3 player using a rca-to-1/8 adapter directly to the RCA cable which was connected to the amp/sub. with the cable in it's original location, this made the sub turn on and the servo light up....which is the exact same thing that was happening before. So i pulled the entire rca cable out and checked it. All of the outside was still intact but you could easily see where it had been pinched, but nothing had broken. I then plugged the mp3 player in again (with the rca line not running behind any panels, etc.) and the sub/amp worked perfectly. So i thought i figured it out.
just now, i decided to rerun the RCA, taking care not to pinch it. As soon as i plug it in to the head unit i get the old problem...powers on and servo lights up. So i took the rca out from behind all of the panels and just ran it straight to the head unit, not hiding it at all....same thing.
so once again, I have no idea.
Old Jan 13, 2009
sweetbrett's Avatar
new RCA cable didn't fix it. I guess now I need to find some one to swap sub/amps with to see if its a problem with my car or with the basslink.
Old Jan 20, 2009
sweetbrett's Avatar
i finally got down to bestbuy this weekend to have one of their install guys see if he could figure out what was going on. I spent 2 hours there with the guy going thru all the same things I did and getting the same results as me. Finally, he went and got an already opened amp from the sales floor to swap in....and it worked perfectly fine. So we decided it was the basslink itself.
I got a new one delivered today and threw it in the car. It works perfect. relieved that it works now but still mad it took so long to figure out
Old Jan 20, 2009
civicplaya's Avatar
wait you got a new amp and it works fine now?
Old Jan 20, 2009
is there an echo in here, or is it just me?
Old Jan 21, 2009
civicplaya's Avatar
