Constant 12V not work, clock keep reseting
Old Sep 20, 2007
ghostkiller's Avatar
ghostkiller is an unknown quantity at this point
I just installed a new stereo system. The 12V constant is not working. I changed to use the power from the cigar lighter. But this make my clock reset everytime I turn on the car.
Anybody has suggestion to fix this. Any diagram or method to check where the 12V is not working?
Thanks alot
Old Sep 20, 2007
Alpha 5's Avatar
Re: Constant 12V not work, clock keep reseting
It would be nice to know what car I am dealing with.
Honda civic, what? I need to know the year and trim level coupe or sedan.
Old Sep 20, 2007
Alpha 5's Avatar
But without the specifics, I can give you this.
http://www.the12volt.com/installbay/...ard/Honda.html
Old Sep 21, 2007
Thanks for reply
My car is a Civic 95 DX 1.5 4dr.
Can you plz help me with this.
Old Sep 22, 2007
electric130's Avatar
well, since the cigarette lighter turns off every time the car turns off, that wouldn't be a good choice. if you got a harness with the stereo, then it should have matched up no problem. i think it's either the yellow or red wire. if you didn't get a harness and cut into your factory wires, then you'll need to get a wiring diagram and find which wire is the constant power from your car. go buy a Haynes manual for your car if you don't already have one. they have wire diagrams in the back.
Old Sep 24, 2007
Thanks for replying. I plugged the power to the 12v constant correctly, because the clock start running when I connect the wire. And the clock is supplied by the 12v constant.
So there must be a problem in wire from 12V to clock. I dont know any fuse or anywhere around to control this 12V constant.
Thanks
Old Sep 24, 2007
MURDOCK's Avatar
My cats breath smells like cat food.
MURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond reputeMURDOCK has a reputation beyond repute
Thanks
Why don't you use a circuit tester to make sure the clock is hooked up to the hot wire?
If you don't have one make your own with a small bulb and two wires.
Old Sep 24, 2007
Thanks
there's the memory power and the main power. even if the memory power is not connected, the clock will start when the radio is powered. if there was a problem in the wire to the clock, then i'd say the clock wouldn't work at all. either way, you need to get a meter or something to do some testing with.
Old Sep 24, 2007
MURDOCK's Avatar
What about the station memory presets are they reseting also?
If so your def not wired to the constant hot.
correct me if I'm wrong.
Old Sep 25, 2007
Alpha 5's Avatar
Talking Re: Constant 12V not work, clock keep reseting
1995 Honda Civic Stereo Information
Constant 12V+Blue/White (Blue with a White stripe)
Switched 12V+ Yellow/Red (Yellow with a Red stripe)
Ground Black
Illumination Red/Black
Dimmer n/a
Antenna Driver's Pillar
Front Speakers 6 1/2" Doors
Left Front (+) Blue/Green
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Rear Speakers 5 1/4" Rear Deck
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
Old Sep 25, 2007
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
Constant deck power is ran off a 7.5A fuse under the hood. The fuse is labeled either Back-Up or Fuse# 32. Fusebox appears to be passenger side, rear of the engine bay. This fuse also supplies power to the clock and your Engine Control Module.
CarStuff
Dec 6, 2020 12:52 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
ORskier
May 3, 2015 12:54 PM
dooner24
Apr 14, 2015 07:51 PM
