Notices
pads wont fit help!
Old 02-20-2017
5hamers's Avatar
5hamers is an unknown quantity at this point
pads wont fit help!
i cant fit my new monroe brake pads in holding braket they really hard going on ? i cleaned my bracket and greased it still real hard to go on????
Old 02-20-2017
"Honda - tried, true & tested...!"
brags's Avatar
brags is an unknown quantity at this point
Re: pads wont fit help!
I ran into the same problem Years ago. Your new brake pads won't fit
in the calliper bracket probably because the calliper bracket and shims are rusty
and need cleaning.? take the calliper bracket off take the inside shims off and
make sure you thoroughly clean any rust away with a wire brush put every thing
back if the brake pads still won't fit.? its because Your using an aftermarket Pad
no worrys..! heres a trick i Learned to Fix that. file the ears on the ends of the
brake Pads just enough that they slide back and forth on the calliper bracket
then when it slides easily back and fourth grease the ears and put them in
found this video from my files for You... Remember too take Your time You
You will get it to fit right as good as using an OEM sized brake Pad
Old 02-20-2017
5hamers's Avatar
Thumbs up Re: pads wont fit help!
THANKS!!! brags
Old 02-20-2017
brags's Avatar
No Problem... i have always used aftermarket brake pads i.e.
monroe, Ate, Jasper. etc...
what i notice when using aftermarket brake pads even though they say on the
outside box OEM TO FIT Your make and model i found that all of the Ceramic
brake pads i bought didn't fit that way...? even after cleaning the entire calliper
bracket only ones that came close were the Ate brake pads even those i had too
file down a little to fit in. i think its due to the castings many are made in china
mind You the brake material itself is Excellent in Quality. No noise good Life span on
them though i just notice i gotta file every one in the Box every time
i buy them.. LOL did You change Your rotor discs too what kind did you use?
Old 02-20-2017
5hamers's Avatar
hey what-up yoo i had to file every pad -just finished i got a set of cheap duralasts from autozone $26.00 bucks each dont care bcause' im selling it soon thinkin of getin in a 2006 or 8th gen civic if the cost is right at honda stealers baha. i still gota flush the fluid with a friend and put back my wheels thanks again for the quick respone
