bucking problem
Old Feb 5, 2017
5hamers's Avatar
5hamers is an unknown quantity at this point
bucking problem
my engine sometimes bucks like its not getin gas its a 91 civic what is it?
Old Feb 7, 2017
mac25's Avatar
Dr Krieger of Modification
Re: bucking problem
It could be many things.
Just to rule out clutch transmission issues it is an auto right?
Start off with the dummy checks
-battery connection is tight, no corrosion, wires are connected to terminals.
-major ground points, engine, transmission, head.
-scan for codes
-fuses (sometimes there is a small break which will let current flow, but not properly check them all with a multimeter for resistance).
-relays.
After this you will need to check the fuel an ignition system.
-fuel pressure (test with gauge and if possible while driving)
-ignition pulse (injector signal)
-spark
Old Feb 7, 2017
abhijja's Avatar
autoparts
abhijja is an unknown quantity at this point
Re: bucking problem
First off do the following:
Replace the fuel filter. Probably it is original or at least 10 years old.
Once done, slightly undo the bleeder bolt on the feed side of the filter and crank the car. You should see fuel spray.
If you see fuel, then look at replacing the fuel pressure regulator as chances are that is also partially clogged as well.
Then see if the car starts and keeps running.
Do these first.
Another thing to look at is a bad solder joints on your main relay as well..
