Cranking but not starting
Old Jan 7, 2017
mcollins8383's Avatar
mcollins8383 is an unknown quantity at this point
95 turned off at night next morning turns over but no start. All cylinders are getting spark. I can hear the fuel pump turn on and there is fuel pressure at the filter. I have visually inspected the inside of the ECM and I dont see any signs of defect. Any suggestions on what to look at next would be greatly appreciated.
Old Jan 8, 2017
Re: Cranking but not starting
Are the spark plugs soaking wet?
Old Jan 8, 2017
When I pulled the spark plugs to check the compression there was oil in a couple of the tubes. I did go ahead and pull the valve cover and replace the o rings in the cover and gasket. Hopefully that will correct the oil issue.
Old Apr 11, 2017
aarronc's Avatar
aarronc is an unknown quantity at this point
I have the same issue with a 95 and the same situation (cylinders have spark, have fuel pressure...) so if you find a solution I would be interested in hearing what you did and if I can get mine going I will post what fixed it here.
Old Jul 13, 2017
larry yellnats's Avatar
larry yellnats is an unknown quantity at this point
oil on the the plugs is definately the o rings undervalve cover. Check fuel, and spark, if thats good check compression. if that passes Check for a solid Ground. Good Luck bro
