B18C compression
Old Sep 9, 2015
NROD315's Avatar
NROD315 is an unknown quantity at this point
B18C compression
i recently compression tested my b18c in my eg and the results i was was getting were
1 Wet: 210psi
2 Wet: 210psi
3 Wet: 240psi
4 Wet: 240psi
I was wondering why the difference in cylinders. Thank you.
Old Sep 9, 2015
Re: B18C compression
What results indicated a need for doing a wet compression test?
How about posting the results of a normal DRY compression test, on a hot engine.
Crank it until the gauge quits climbing, plus a few more hits just to make sure it reached its max.
Old Sep 9, 2015
NROD315's Avatar
my results were around 190-200 psi dry. I had it full throttle and cranked over an even amount of times 4-6 times cranked over
Old Sep 9, 2015
That would not give me cause to try a wet test.
Are you chasing a running problem or something?
Personally, I crank until I'm positive the gauge is maxxed out and will not go any higher.
I also note cranking RPM and may put a battery charger on so cranking speed stays consistent for all cylinders.
Old Sep 11, 2015
NROD315's Avatar
im just having all types of issues with my motor so I just want to run tests to start knocking out what could or couldn't be wrong and these are the result I got. Should i not run the test again?
Old Sep 11, 2015
If you had good compression numbers with a normal test, there is no reason to do a wet test.
Old Sep 12, 2015
emich's Avatar
emich is an unknown quantity at this point
1 Wet: 210psi
2 Wet: 210psi
3 Wet: 240psi
4 Wet: 240psi
You could have slightly bent valves on cylinders 1 and 2
Old Sep 12, 2015
Mad Dog Tannen's Avatar
That looks like good compression to me. Leave it alone. Valves are not bent!
A little difference between cylinders is fine, the rings and valves do not all wear exactly the same. The valves may not be sealing like new or may be worn a little causing the slight difference. Nothing to worry about.
That is a good test, within service limits!
Old Sep 12, 2015
My first thought:
Unequal oil distribution for the wet test, more oil went in the last two than the first two.
Excessive oil takes up space in the cylinder, falsely alters the effective compression ratio, and therefore falsely increases the compression test reading.
Tons of carbon buildup in a cylinder or on top of a piston can have the same effect.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
runawaykinms
15
Mar 22, 2019 10:32 AM
anubis62
Sep 27, 2015 12:56 AM
yyyktk1
Sep 12, 2015 04:02 PM
NROD315
Sep 4, 2015 09:22 PM
