91 dx won't stay running
Old Nov 15, 2014
Cadaver666's Avatar
Cadaver666 is an unknown quantity at this point
Hey guys I've got an issue I can't seem to resolve. I've got a 91 honda dx hatchback. It will start and run find for about 20 min then it stalls and wont start again. It has a new fuel pump fuel filter. New ignition coil spark plugs and rotor. If I let it sit for awhile it will start and run again, but only for a max of 20 min. When it won't start its getting fuel and spark. I've already check the main relay and all the solder points look good. I'm thinking ECU? And ideas???
Old Nov 23, 2014
redbullmorton's Avatar
redbullmorton is an unknown quantity at this point
Re: 91 dx won't stay running
I have the same problem! I have a92' civic hatch DX and just replaced the fuel pump and also the fuel filter. It stalled and died and wasn't getting fuel so I replaced them both. Now after a few tries it will start and Idle but as soon as I give it throttle it will die. A few more cranks and it will start and idle but that's it. I have no more ideas to try.
I also back in August replaced the distributor with a new one.
mikemc422
Aug 9, 2018 05:41 PM
davidarenberg
May 16, 2015 08:45 AM
Supramk3
May 11, 2015 07:55 PM
hokiedad4
May 3, 2015 10:06 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
