Lost power to all gears!
Old Aug 23, 2014
R.West's Avatar
R.West is an unknown quantity at this point
Hello!
I drive a 1991 Honda Civic Si (manual) with about 280k miles on it, and until just the other night it ran beautifully. I was going about 5 - 10 mph in my apartment parking lot, and it all of a sudden lost power (I had my radio on, so I don't know if there was a distinctive noise). I immediately put the car in neutral and turned off my music.
The clutch feels the same as it always has, and there seems to be no resistance shifting into any gears, however as soon as I place it in gear and release the clutch it starts to make a very loud clanking noise. When running in neutral is sounds like all is normal.
Right now I have a total loss of power to the wheels.
I would like to find out what exactly is wrong, and if this is something I can fix on my own. I am fairly mechanically inclined, have plenty of free time and a willingness to learn.
I appreciate any help!
Old Aug 23, 2014
Re: Lost power to all gears!
Does the speedometer show some speed when you do this, or does it remain at 0?
If it shows some speed, then look for an axle broken, CV joint broken, or axle stub pulled out of the trans.
If it shows 0 speed, then it probably broke something inside the trans or clutch.
If you locate the source ot the noise, I'm pretty sure you will have found the problem.
You should have already completed the previous step on your own.
jbradley4809
Apr 7, 2017 04:23 AM
Supramk3
May 11, 2015 07:55 PM
BootyDo
May 8, 2015 05:36 PM
CiviCKiD
Jan 4, 2002 05:13 PM
silvervtec01
Dec 9, 2001 08:50 PM
