1993 Honda Civic EG Overheating
Old May 8, 2014
MR.PAKO661's Avatar
MR.PAKO661 is an unknown quantity at this point
I need to help to figure out whats going with my car, I have changed the thermostat a couple times and it overheats still. i have checked the hoses with the thermostat in and they are fine. I have drained the coolant and put new coolant in. so i have my car without a thermostat now, also my car is running a little bit lean, im not sure that is the reason why my car lean since i have no thermostat
I NEED HELP PLEASE!!!!!!
Old May 8, 2014
TiggerDX's Avatar
TiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of light
Re: 1993 Honda Civic EG Overheating
Have you checked to see if the fluid is flowing when running? You may also have something blocked. You may also have a bad temp sending unit.
Old Jun 21, 2014
Netsurfers's Avatar
Netsurfers is an unknown quantity at this point
Check to see if its got heat flowing through the vents via HVAC controls. If its kicking decent heat out then the coolant is flowing, And yes no thermostat can cause a rich condition, Not sure about lean. Because when you first start a cold car it goes in to open loop fuel trim, Which is a strategy much like a choke on a carburetor. Dumps fuel in and restricts air for a easier starting and stays like that before it gets to a certain temperature, then FRED takes over. So if your car isnt reaching this temperature, It remains in open loop and doesnt change to closed loop. I would definitely get the coolant system pressure tested, It may be a blown head gasket
Civicman92296
Apr 23, 2015 09:22 PM
jessicakaybby
Apr 20, 2015 12:11 PM
