Hose leak
Hose leak
Just a wee pinhole leak in the number 3 hose, but what do you call it? I think I should be able to pick it up at the local auto parts store, but because of the age of the car (1990 Honda Wagoneer) I'm not positive. If I have to order it, then that's what I'll have to do, but even then what am I ordering? I've got something I'd like to be able to drive to myself tomorrow night. Hahahaha!
Re: Hose leak
Yeah you should be able to get one. If you can, drive to an auto shop (O'Reilly's is my choice), take it out if you can, and bring it to the counter. They'll hook you up.
Re: Hose leak
Thanks. That's what I was figuring on. I bought it from a guy who runs a shop down the street, I'll pop it down there. No issues running short distances. God willing, I can run by tomorrow night.
Re: Hose leak
Well I did stop in to my local Pep Boys and what they have is vacuum or heater hose available by the foot. It certainly looks like it will do the job, my only concern is will this type of hose hold up to the heat of the coolant that's going to be running through it. I obviously can't have the piece melt on me. I assume it'll do, but would like to be sure. It's not an emergency must fix now, so I'd rather do it right the first time.
Re: Hose leak
What should I use and where the hell can I get it?
Uhh, maybe not due to shelf life issues. How old would OE replacement hoses be now?
If you got a pinhole in one of the small hoses, and it's almost 25 years old now.... and you have a pile of other small coolant hoses on there that are just as old as the leaker, then I'd say to replace all of them before you get stranded with a huge problem.
So many of them are pre-formed....bulk hose sometimes can't be used due to kinking instead of smoothly bending. IDK if anyone even sells a suitable coolant hose in bulk that size.
It's about 8mm ID, right? (5/16") Fuel line can be had in that size but probably won't last but a year or two in antifreeze.
Heater hose is too damn big, I suppose?
Bingo!
www.gates.com
Coolant Hose and Systems
Safety Stripe® Heater Hose
EPDM hose constructed for extra-long service life.• Unaffected by most coolants and non-oil based coolant additives.
• Unaffected by high cooling system pressures.
• Good resistance to high temperatures for extended periods of time.
Various small sizes there.
Check it out, page 8
http://www.gates.com/oreilly/PDFs/Coolant%20Hose.pdf
For bending corners without kinking, see page 12 for "Unicoil"
The name oreilly is in that link, give your local Oreilly store a call of you have one.
HTH
Re: Hose leak
Don't have O'Reilly's here in PA. It's Pep Boys and AutoZone.
Re: Hose leak
There's far more parts suppliers than that. NAPA? CarQuest? I'm sure there are local independent stores that cater to professionals instead of DIYers. Bust out your yellow pages. Seek them out.
It's Gates hose. You have a part number now, all you need to do is find a supplier willing to get what you need.
http://www.gates.com/where-to-buy
liagreenhalgh92
Jul 21, 2015 01:31 PM
Causemo
Jul 5, 2015 06:42 AM
