95 honda civic ex engine parts
Old Oct 1, 2013
Milktitties's Avatar
Milktitties is an unknown quantity at this point
Exclamation 95 honda civic ex engine parts
Im in need of parts for this vehicle but local junkyards dont have the same car. so i was wondering if any other year civic parts will swap into it. its a 95 ex d16z6 the parts are:
exhaust manifold
distributor
motor mount
torque converter and flywheel
dont know much about civics. all input is much appreciated.
Old Oct 1, 2013
Re: 95 honda civic ex engine parts
The wrecking yard should have an interchange guide (most use the Hollander Interchange guide http://hollanderinterchange.net/).
Ask them what other years and models will swap.
Old Oct 1, 2013
I've asked a couple places that I've called and they said that they don't. So that's why I was hoping to get some info from be one on here
Old Oct 1, 2013
Ok, I guess you will have to compare part numbers then.
Wiki says
D16Z6
VTEC
Found in
  • 1992–1995 Honda Civic Si
  • 1992–1995 Honda Civic EX, EX-V
  • 1992–1995 Honda Civic ESi (European Market)
  • 1993–1995 Honda Del Sol Si (US)
  • 1993–1996 Honda Del Sol ESi (European)
So, pick your models there, then go to a parts catalog and check out part numbers for each part you want, and look through all the years stated above.
Time consuming I know, but that's one way to get an answer.
Here's a couple US catalogs
http://www.hondaautomotiveparts.com/
http://estore.honda.com/
HTH
Old Oct 2, 2013
cool thanks man. thats helpful!
Old Oct 3, 2013
if any one else that comes across this and knows the answer feel free to chim in! id like to get more then one persons answer.
jessicakaybby
Apr 20, 2015 12:11 PM
ashleymmackey
Apr 18, 2015 09:48 PM
dooner24
Apr 14, 2015 07:51 PM
