del Sol stalls on takeoff
Old Jul 26, 2013
SKS3RD's Avatar
SKS3RD is an unknown quantity at this point
My son's 1993 del Sol, 1.5 liter injected engine, 180,000 miles, manual trans, has developed a problem where it will sometimes stall after a brief period of idling (like at a stop light). It will idle fine (around 800 RPM), but as soon as he puts it in gear and touches the gas pedal, it will immediately stall (no sputtering). Happens when the car is warmed up and seems to happen more often if the car is stopped facing uphill. It sometimes takes several attempts to re-start after this happens (fun in traffic!)
Recent (within the past 1000 miles) work done: rebuilt cylinder head, PCV valve, air filter, spark plugs, and main relay. He ran some StarTron in the last tank of gas, hoping it might be water in the fuel, but no change. The car runs fine otherwise, no Check Engine lights.
Any ideas are appreciated.
Old Jul 27, 2013
go-part's Avatar
Former Sponsor
go-part is an unknown quantity at this point
Re: del Sol stalls on takeoff
http://www.buzzle.com/articles/sympt...on-sensor.html
Has the tps been tested yet?
Old Jul 28, 2013
SKS3RD's Avatar
[QUOTE=
Has the tps been tested yet?[/QUOTE]
I just tested it:
Battery voltage 12.25
Red/Green wire .48 with TPS closed with smooth transition to 4.48 volts WOT
Old Sep 4, 2013
SKS3RD's Avatar
Re: del Sol stalls on takeoff - FIXED!
My mechanic installed a new distributer, and it seems to have fixed the stalling issue completely. Three weeks now without a problem.
Thanks to those who responded.
SimpleUser
Apr 24, 2021 02:54 AM
jackoncruzpr
Sep 29, 2015 07:59 PM
2.0.0.2
Sep 14, 2015 06:38 PM
thaler4cuse
Sep 7, 2015 08:25 PM
PierrePierre
Aug 12, 2015 02:42 PM
