Do you like solving a mystery? 1993 civic
I am about at my wits end with my sons 1993 honda civic about a week ago he parked it only to come back out to try to drive home car turns over but stalls out within a second. We have replaced the fuel pump, the fuel regulator, fuel filter,spark plugs,main relay he has checked to make sure there is spark. We are at a loss at this point any help would be appreciated at this time
Re: Do you like solving a mystery? 1993 civic
IACV- Idle air control valve. It is located to driver's side of the throttle body. You can unplug it to test if this is your problem, car should stay on and idle high .
do you know how to check trouble codes. Under the glove box there are some connnectors , a 2 wire and a 3 wire. Use a wire to connect the blue 2 wire sockets together while the ignition is in on position and count the number of blinks of the CEL .
I had been looking to see if there was such a thing everything I saw online was telling there was a box so there are wires i need to connect and then i take it the light that i watch to flash is on th drivers side dash?
If this primarily happens in warm weather when it gets hot inside he car it will be a main fuel relay. Its hidden pretty well under the drivers side dash almost behind the kick panel. Check for power at #7 terminal, black/yellow wire when the car wont start. You should have battert voltage as this is the power output to the pump. If this sort of thinghappens and 15 minutes later it starts, and if it seldom happens in cooler weather skip the test and replace it. I've seen this hundreds of times in 20 yrs.
For friends only:
I take them apart and resolder everything on the board.
Permanent fix, and almost free. Worth a few McDoubles for 10 or 15 minutes of my time.
For customers at the shop, they get replaced.
Worth at least a couple hundred McDoubles.
But
There was a time several years ago when Honda had them on indefinite backorder and we couldn't get them, all I could do for customers was resolder them. Haven't seen any come back thus far.
But
Cilvic
Nov 15, 2001 04:54 PM
WeRkX
Nov 1, 2001 10:33 PM
