pls help me identify this parts name.
please help me identify the name of this part from my 1994 honda civic LX 4 door sedan. it is a 1.5L 4 cylinder 16 valve engine with a carburetor (ph15 philippine made). thank you.
this part is located under the carb
i think this part affects the idle of my car. the idle is erratic i think due to the damage to the said part seen in the last 2 images. a link to a supplier of said part would also be greatly appreciated. thank you.
Re: pls help me identify this parts name.
I really can't help with the part it's self. What you might try is taking it out, clean it up with a solvent and small wire brush, check the valve to make sure it has spring action, JB weld it back together. That may get you down the road until you get a replacement.
Looks like a vacuum manifold of sorts. Wouldn't be able to tell you without an engine code.
Edit: google search tells me you got the same answer on h-t. If it is indeed a vacuum manifold, you can probably finagle an aftermarket vacuum manifold to replace the existing one.
While looking up an older version (from an 1985), it looks like they describe it as "JOINT, NINE-WAY (NOT AVAILABLE)", not the exact one you need but may give you an idea of what you are looking for.
If you find a parts diagram from honda, it should be under Engine / Install Pipes-Tubes
guys, i need confirmation if this part's name could be the "PORTED VACUUM SWITCH"?
if it indeed is a ported vacuum switch, my problem now is to find said part with 6 ports :scared: maximum ports i could find is 5 ports :ugh:
thanks
thanks
Looks like splits up the vacuum direct all your hoses. See if you can find the part here: http://www.hondapartsunlimited.com/index.php?p=home
My goofy self managed to miss the post that said you could find one with 5 ports.
If you can find one with 4 ports, it should work sense 2 of the 6 ports are looped to eachother. If not, take the 5 port switch and cap the one closest to the switch off.
Worst case scenario, take the 2 port switch and a pair of Y or T couplers. Maybe the closest 2 and the farthest 2 work off the same vacuum. I kinda doubt it, but if nothing else works, it might be worth a shot trying.
Touge
Ottawa
May 23, 2015 05:39 AM
ORskier
May 3, 2015 12:54 PM
