|Which Oxygen Sensor Wire Is Which 95 Civic Ex
Old Apr 13, 2012
driz's Avatar
driz is an unknown quantity at this point
I have gotten a generic oxy sensor for my EX and it has no plug with it. Which wires are the heater and which are the sensor wires of the 4? I looked all through the manual and it it shows it someplace then I couldn't find it.. Of course the sheet with the sensor gives several possibilities and none of them match the wire colors on my Ex.
Old Apr 14, 2012
Re: |Which Oxygen Sensor Wire Is Which 95 Civic Ex
On the car harness plug:
orn/blk (neg) and yel/blk (pos) are for the heater
wht is O2 input to the PCM
grn/wht is sensor ground, shared with several other sensors (TPS, ECT, IAT)
Chop the connector off of the original O2 sensor and use that to connect instead of hacking up the cars wire harness.
You will need it later when you finally realize that the car does not like the universal Bosch O2 sensor and that is why it keeps setting codes.
"Hear me now, believe me later."
HTH
Old Apr 14, 2012
lazlong's Avatar
Agree. These cars only like DENSO or NGK and sometimes they don't like NGK.
Old Apr 14, 2012
driz's Avatar
HTH
FWIW the sensor is made by Borge Warner and I guess I;ll see if it will work any better. I have had so much luck and fantastic prices shopping for sensors ect on Ebay ect that I figured it was worth the shot for $23 in that if it doesn't do the deed I can just pull it and save it for the next car Boy, I put in about an hour and a half digging through the online manual to try to pin that simple thing out. Thanks for the info. I already did a brake job and changed out 2 sets of snows this week and really don't want any more investigative headaches than I already have.
Old Apr 14, 2012
Most of the time when I get them, it is the heater circuit resistance that is wrong.
If the car doesn't like it, use Denso.
Actually, just read the name stamped into your original sensor (assuming it is really original), use the same thing. Probably Denso.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
CarStuff
Dec 6, 2020 12:52 PM
bsmiley
Apr 27, 2015 01:27 PM
tkcne
Apr 18, 2015 02:33 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
