Overheating on a Honda Civic 92 Sedan
Old Apr 1, 2011
honvic's Avatar
honvic is an unknown quantity at this point
  • My car cooling system would get hot and boil especially when I am in traffic.
  • You could hear it boiling from inside the car
  • When I open the bonnet there would be steam leaking out of where the tube from the radiator cap to the external water tank are
  • This would drain all my water out of my radiator and cause my engine to overheat quickly
  • I decided to drain my cooling system and place new water with anti boil, anti freeze and anti corrosion liquid mixed.
  • This stopped the boiling from happening but the heat would still rise to red as shown in my temperature gauge.
  • I noticed that my fan does not come on at all when it overheats
  • I have had this problem before and changed the thermostat about a year and a half ago
  • I have decided to hard wire the fan by removing the thermostat plug and placing a wire on it. This made the fan go on 24/7 when the car is on
  • I am thinking this could be the thermostat again since the fan goes on when I hardwired it. But I am unsure because I replaced it 1.5 years ago
  • I am confident that without the fan coming on, this is what is causing my car to overheat when I am in traffic. When I am on the freeway, I am ok.
Do you guys think this can also be the thermostat, whats the life span on thermostats?
Thanks
vtec92
May 4, 2017 03:20 AM
jessicakaybby
Apr 20, 2015 12:11 PM
aus10
Apr 13, 2015 09:26 PM
Lightman
Nov 10, 2001 06:44 PM
Crash2002
Oct 26, 2001 05:02 PM
