93 civic
Old Dec 27, 2010
Nik606's Avatar
Nik606 is an unknown quantity at this point
93 civic
hey guys im new to this, i just bought a 93 civic, i put in brand new plugs wires and cap and rotor, no it runs fine up until it is fully warmed up and then it will star to misfire and choke. the thing that has me confused is that its only when its fully warmed up. thanks for your time!
Old Jan 3, 2011
StaticFire450's Avatar
Bringer Des Blutes
StaticFire450 is an unknown quantity at this point
Re: 93 civic
Check and make sure you have TDC(Timing). I am guessing you replaced the cap and rotor for a tune up reason. Your problem may be Ignition Coil, Ignitor, or Regulator.
Try test driving it with a different Distributor all together.
I had a bad Ignition Coil, and once I hit higher RPM, it would putter/backfire at random times. Got worse as it warmed up..
jonavin
73
Oct 4, 2004 07:18 PM
locozoko
Apr 6, 2002 09:00 PM
silvervtec01
Nov 4, 2001 06:56 PM
locozoko
Nov 4, 2001 05:45 PM
WeRkX
Nov 1, 2001 10:33 PM
