fuel injectors
Old Jan 27, 2010
93 honda's Avatar
93 honda is an unknown quantity at this point
fuel injectors
I have a 1993 honda civic dx and have a question about the fuel injectors. The car runs really rough and does not seem to have much power (had to drive in third gear all the way to work)(it is an automatic fyi). I unplugged the injectors one at a time and found one that is bad, when i pulled it off it made no change to how the car ran. So i guess my question is will that one injector not working cause my car to run this way or is there maybe some deeper issue. I recently changed the head gasket and i set the timing so i don't think that is the problem unless i am missing something....any help please.
Old Jan 27, 2010
Re: fuel injectors
yeah one bad injector is causing misfires for that cylinder and the whole motor runs rough.
Old Jan 27, 2010
RonJ's Avatar
RonJ will become famous soon enough
Re: fuel injectors
Your test tells you that there is one dead cylinder. It does not tell you that the injector is the problem. The problem could also be the lack of spark or low compression. First test for spark, then test for injector pulses using a node tester, and then cylinder compression.
Yes, one bad cylinder can cuase an engine to run poorly.
Old Jan 27, 2010
93 honda's Avatar
Re: fuel injectors
Thank you both for your responses. I will be digging deeper into this.
SimpleUser
Apr 24, 2021 02:54 AM
GritzNGravy
Aug 19, 2015 03:03 AM
martinsmartin
Aug 15, 2015 07:34 PM
fred57
Aug 1, 2015 08:45 AM
Green02civic
Jul 27, 2015 10:48 PM
