Engine Performance Modifications Post information/questions about Forced Induction, Nitrous, Engine Building and Swaps here.
98 civic 1.6l sohc swap with b18b1
Old Oct 9, 2010
mcnug's Avatar
mcnug is an unknown quantity at this point
what do i need to swap my 1.6 with a b18b1 i have a full integra that i am taking the motor out of to put in my 98 civic si
Old Oct 9, 2010
02civicsi02's Avatar
Low and slow!
Re: 98 civic 1.6l sohc swap with b18b1
If your car is already manual I am assuming to swap a b series in your car you will need motor mounts, ecu, wire harness, shifter linkage and maybe shifter assembly and well motor and tranni of course.
Old Oct 10, 2010
mcnug's Avatar
do i need to switch the cv joints and everyting too or can i use the civic ones?
Old Oct 10, 2010
mcnug's Avatar
and can i use the motor mounts out of the integra?
Old Apr 20, 2011
Soldierboy87's Avatar
Soldierboy87 is an unknown quantity at this point
I'm doin the same exact swap. My civic is a 96 ex. I have the integra...all I need to do is gather my parts. The integra is an auto so I think I'll need a flywheel, transmission, cv shafts, shift linkage, ecu, and wire harnesses. From what I heard I can use the integra mounts and it should bolt right in. I'm not 100% sure how to do the wire harnesses so any pics or info on exactly where to look and how to do the electrical work would be greatly appreciated. It's a B18B1 so there's no vtec.....that should make the wiring a lot easier.
Old Jun 3, 2011
kyle79's Avatar
kyle79 is an unknown quantity at this point
i just bought the b18b1 to put in my 98 honda civic and i was doing some homework on it to see what i need and on another site someone told me that air care wotn allow it? is this true if so how come?
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
Tybonater
Apr 24, 2015 07:03 PM
Rinzlor
Apr 24, 2015 10:33 AM
jackoncruzpr
Apr 16, 2015 12:29 PM
CapYoda
Nov 11, 2001 05:17 PM
