Engine Performance Modifications Post information/questions about Forced Induction, Nitrous, Engine Building and Swaps here.
Methanol Injection
Old Feb 5, 2008
TurboB20's Avatar
TurboB20 is an unknown quantity at this point
Methanol Injection
I was just wanting to check for sure. But with my setup for example B20B/B16a2 w/ Greddy turbo kit. Would Methanol Injection help me in any ways other than obviously more power? More so would it help with prolonging motor life and keeping things a little safer in the bottom end until I get it sleeved?
Thanks
Old Feb 9, 2008
cleanmagcivic's Avatar
cleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trustedcleanmagcivic should not be trusted
Re: Methanol Injection
it will help. you can lower the psi u us but in a way get the same hp. it help by lowering your charge temp and by raising ur octane level.
this is a quickie but soon the real turbo guys should be in here.
Old Feb 9, 2008
andyman97's Avatar
Turbo Guru
As far as b20 blocks go, I have no personal experience but people I know that do have experience have told me that they won't hold much power before they go. I wouldn't chance it unless you have a spare block. It isn't about the "psi" its about the cylinder pressure and the power you're making.
Old Feb 12, 2008
TurboB20's Avatar
Yeah thats kinda what I figured. I probably wont go with meth. injection. I am going with another tip I was given which was to swap out the Integra type R cams in it for some more turbo friendly ones and re-tune it. This way I can get some cooler temps.
Old Feb 12, 2008
andyman97's Avatar
Turbo Guru
If you're considering cams, look into gsr's for boost.
Old Feb 12, 2008
TurboB20's Avatar
Yeah thats what I am told I should go with. Thanks man
h4ldol
Apr 24, 2017 08:16 PM
RIPSAW
Aug 16, 2015 12:14 PM
15EXCoupe
Jul 30, 2015 12:59 PM
iamboo
Engine Swaps
36
Mar 4, 2004 04:05 PM
futurersxswap
33
Sep 28, 2003 01:33 PM
