2000 Honda Civic
Old Mar 25, 2008
00cex's Avatar
00cex is an unknown quantity at this point
2000 Honda Civic
I posted this is in the 6th gen section but really didn't get any help....
Hello all new to the forum but I highly doubt many people have my problem...I have an upwards of 600 pounds of audio equipment in my trunk and was wondering what do you all think would be a good cheaper way of handling that weight? Also do you think I need to do any upgrades to my engine or tranny? Thanks for your time, Mark.
Old Mar 25, 2008
Envy's Avatar
Diamond Member
Envy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of light
Re: 2000 Honda Civic
did you mean 60 pounds?
Old Mar 26, 2008
Nitro Express's Avatar
Nitro Express is an unknown quantity at this point
Honestly 00cex, there is NO good (cheap) way to handle 600 lbs in your trunk. A 2K EX Coupe has a curb weight of 2,513 lbs. It has a GVWR (Gross Vehicle Weight Rating) of 3,440 lbs. This means you can put a max total of 927 lbs in your vehicle (not all in the trunk). Weight just in the trunk effects the rear suspension much more than if it was located forward of the rear tires. So, if the driver and passanger each weigh 150 lbs, you have reached the GVWR. This is going to put lots of stress on everthing.
Old Mar 26, 2008
00cex's Avatar
Ok thank you for your inputs no I meant 600lbs. What are your suggestions? I don't know the stock springrate but I want to get new shock/struts to help with the weight.
Old Apr 7, 2008
00cex's Avatar
What is the stock spring interior diameter, exterior diameter and height of the spring?
Old Apr 17, 2008
Yaktizzle417's Avatar
Yaktizzle417 is an unknown quantity at this point
If you don't mind my asking....
How do you accumulate 600lbs of audio stuff?
jessicakaybby
Apr 20, 2015 12:11 PM
liljoe
Nov 4, 2001 01:27 PM
