Hear something clicking inside car
Old Sep 14, 2017
DaBrother's Avatar
DaBrother is an unknown quantity at this point
So car is running better now after a pile of issues after replacing timing
belt.
Now hear a click inside car. It almost sounds like the sound from the turn signals and hazard lights flashing but not quite the same.
Anybody got any ideas what it may be?
Old Sep 14, 2017
Colin42's Avatar
Re: Hear something clicking inside car
is it constantly clicking? buzzing? once in a while, only when you do certain things? turn on ignition, wipers, etc? is the blower on defrost? (ac)
Old Sep 14, 2017
now hear a click inside car.
*wwswd?
Old Sep 16, 2017
DaBrother's Avatar
Clicks about every half minute. No buzzing sound. A/C or heat not on.
Sounds like it might be a relay. Hear it when the car is running. Will have to check to see if it is clicking when the key is turn to ON position too.
Old Sep 16, 2017
Originally Posted by ezone
*wwswd?
WHERE?
*WWSWD?
Follow your ears.
Old Sep 18, 2017
DaBrother's Avatar
Recently noticed that I do not always hear the click.
Believe it is related to the wipers. After turning on or just squirting windshield washer still hear the click after getting wipers to stop.
More of the story.
The wiper switch lever moves to much. Believe it should be more rigid.
Turn the **** to turn wipers on slow speed they may run fast. Then have to wiggle the lever around to get slow speed then it goes back to fast speed. Also have to wiggle the lever a few times to get the wipers to stop.
Fiancée said it use to be worse till she took it to a local independent garage place.
What ever they did made it better according to her. Tonight noticed the CIVIC was marked on the underside of the lever. Guessing this lever is from a junk yard.
Can the lever/switch be accessed without taking the steering wheel off? Guessing a 90 degree screw driver could get to the switch screws???
Old Sep 18, 2017
Remove column covers, you should be able to turn the wheel and clear the screws for the switch.
Old Sep 26, 2017
DaBrother's Avatar
Spent way to much time on this switch last weekend.
Took it apart to clean contacts. Put it back together. Same problem still exists. Now washer does not work. Maybe did not put it back together correctly.
Believe I just need a new switch.
Old Sep 27, 2017
Colin42's Avatar
junkyard like $5-$10
