speed sensor location???
Old May 15, 2012
kglow's Avatar
kglow is an unknown quantity at this point
I have searched and read all the threads on non working speedo's. And I can not find where anyone says where it is located. I have a 2000 Civic 5 spd. The speedo and odm stopped working. I had to replace the engine last week and they do not work now. The car was in a accident and damaged the motor so I replaced it and now no speedo and odo. I do have a CEL on on will pull the codes in the morning but was wondering where the speed sensor is located on my 2000 so I can make sure it is hooked up. Thanks
Old May 15, 2012
Re: speed sensor location???
VSS should be on top of the differential area of the trans.
3 wire connector.
Black, blu/wht, and blk/yel wire colors in my diagram.
HTH
Old May 16, 2012
kglow's Avatar
solved two problems with one fuse. went backto the basics today and checked the fuse for the speedo. it turns out it is the same fuse for the alt. Pulled a code B1298 (if I remember right) and pulled the fuse and it was blown. Put in a new one and the speedo start working and the CEL went out. WOW. I did have to clear the ECU by disconnectiing the battery for about 5 minutes but that is all it took.
I hope this helps someone going forward as these CEL's can be tough.
97-DX-Lover
Jun 14, 2015 06:07 PM
Rushfan1
May 6, 2015 01:20 PM
dragonsblood
Apr 27, 2015 12:28 PM
dooner24
Apr 14, 2015 07:51 PM
