need help wiring a M3-ATX-HV to 2000 honda civic lx
Old Jun 6, 2010
mrdigital's Avatar
mrdigital is an unknown quantity at this point
im gonna be doing a carputer soon im planning out the parts and how to wire it all first
in the pdf manual for M3-ATX-HV which is the psu for the carputer.
it says
Power Input Connectors (right side)
Red Battery + (positive, un-switched battery)
Black Battery - (negative)
White Ignition (To start connect to Battery +).
can someone tell me where in the car these wires connect to ?
i take it i connect the red and black to the batterys +/- but what bout the White Cable?
Old Jun 6, 2010
mrdigital's Avatar
Re: need help wiring a M3-ATX-HV to 2000 honda civic lx
does anyone know?
Old Jun 9, 2010
LVSL3PR's Avatar
LVSL3PR is an unknown quantity at this point
white wire goes to the switched 12v power source. Typically this goes to what is known as ACC, it depends on which vehicle you have but that wire should be located near the steering column. See your service manual for wiring schematics.
On a side note make sure that if you are connecting the carputer straight to the battery make sure that the positive side is fused so you dont blow **** up or start a fire.
jessicakaybby
Apr 20, 2015 12:11 PM
liljoe
Nov 4, 2001 01:27 PM
