Amp problem
Old May 17, 2010
hlferrer's Avatar
hlferrer is an unknown quantity at this point
Amp problem
Hello guys,
I am currently having an amp problem in my system. My system has been working fine for about 6 months now without a problem, but recently it seems like my amp is not fully receiving 12 volts or turning on completely. When i turn on the car my subs are only half way powered but after a while the power up and then again lose power and turn off completely. I did the set up myself and i connected everything correctly, i doubled checked the connections in the amp and everything was intact such as 12 volts, remote wire, ground, and the 1 farad capacitor also is connected correctly. I'm running my 4 gauge wire directly to the capacitor and then to the amp, and also the same for the ground. I also check all the fuses, so my question is what can be causing this problem? could it be the battery? the amp is bad? Any suggestions would be appreciated. Thanks in advance for your help
In my 2000 ex:
2 8" Memphis m class subs 150 w RMS/ 300 peak
1 Farad Rockford Fosgate capacitor
Mtx 250 watt amp d class (i think not sure anymore)
Old May 17, 2010
I ROCK THE SOHC's Avatar
I ROCK THE SOHC is an unknown quantity at this point
Re: Amp problem
It could be your alternator. If its not charging your battery all the way up you wont have full power. Or maybe your battery wont take a full charge. Take your car on the highway with all your electronics off and the alternator will charge the batter quick like the for about 5 minutes. Then see if you still have the problem.
Old May 18, 2010
electric130's Avatar
Re: Amp problem
what voltage do you read at the amp when it's quiet?
Old May 18, 2010
hlferrer's Avatar
Re: Amp problem
Thanks "I ROCK THE SOHC", i was wondering how could i actually tell if my alternator is the one causing the problem? and are they expensive?
Thanks electric130, i will check the voltage reading after I'm done with my finals and let you know. I imagine that the voltage read when there quiet is below 12v `, if it is do you any suggestion what can cause the problem?
Old May 18, 2010
Re: Amp problem
if it is, verify you're battery is doing the same. if it is, i'd say your alternator is bad.
Old May 18, 2010
Re: Amp problem
Go to your local shop and they can put a meter to your alternator and your battery and check the output. Or like i said drive on the highway for 5 minutes will all electronics off. Then turn your radio on and see how much output your amp is putting out. If its running at full power its your batter or alternator. If it still isnt at max output then it is something with the amp or subs
Old May 18, 2010
Re: Amp problem
And no its not to expensive. You can get a oem for around 100-200$
Old May 19, 2010
hlferrer's Avatar
Re: Amp problem
Thanks for all your help, i will try your suggestions and post results after finals lol
Old May 19, 2010
Re: Amp problem
Kool just let me know how it goes
Old May 21, 2010
SPUNKYcivy01's Avatar
SPUNKYcivy01 is an unknown quantity at this point
Re: Amp problem
If you have a cap it shoudlnt matter if the alternator is giving power or not, since that is what a cap is for (correct me if im wrong). It sounds internal in the amp.
Old May 21, 2010
Re: Amp problem
if there's nothing to charge the cap (alternator) then the cap will become a drain on the battery as well.
Old May 21, 2010
Re: Amp problem
Exactly. Just like you can have 5 batteries but if you got nothing to charge them then there is no point for them
Old May 23, 2010
hlferrer's Avatar
Re: Amp problem
Hey guys i finally got done with school and took a look at my system. On the way home i turned off my electronics and drove for about 15 mins and then turned my subs on and they were working great. Once i got home i used a voltmeter and measured the voltage of the car battery, it was 12.36 V as expected and then i measured it at the cap and amp and remote and all of them was 12.36 v, after i turned on the car i measured the battery again and it was 14.3 v because the alternator was on and the amp and cap and remote wire also had the same voltage. So once again i checked all the connections and now the problem is gone i don't know what caused it but so far they are working fine. No idea what fixed it or what was wrong lol. Thanks for all the help
Old May 24, 2010
civicpapi's Avatar
civicpapi is an unknown quantity at this point
Re: Amp problem
Originally Posted by hlferrer
Hello guys,
In my 2000 ex:
Just for curiousity, do you always crank the system? or run it moderatly?
Old May 24, 2010
hlferrer's Avatar
Re: Amp problem
Depends on the day, mostly i play it moderately but sometimes i crank it up a bit.
roverben
Jan 21, 2019 05:16 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
jackoncruzpr
May 24, 2015 12:24 AM
0100010
Dec 1, 2001 03:27 PM
PimpBot5000
Nov 26, 2001 07:15 PM
