All lights dead..
Old Feb 16, 2009
Amps's Avatar
Amps is an unknown quantity at this point
All lights dead..
Hi All,
I have a HC 5 (96-00) and a few days ago, I under the hood wiring new lights, when I picked up some wires which I wired a few months back, that all my lights turned off. I check the fuses and saw np, all my lights are dead, the only 2 that work are headlights. Have no backlights, dashboard lights...have had this issue before, but my mechanic dealt with it...but have not been able to get a hold of him...What is the issue, could it be the fusebox under the hood thats blown. I have no idea.
Thanks in Adv.
Old Feb 16, 2009
Re: All lights dead..
i think you blew fuses?
Old Feb 16, 2009
Amps's Avatar
I have checked the fuses..and cant see anything blown.
Old Feb 16, 2009
04 Honda Civic's Avatar
did you disconnect your negative terminal when doing the wiring? I have learned my mistake on that.
Old Feb 16, 2009
Amps's Avatar
hi, nope didn't disconnect anything, all I did was splice a wire...that I had used before.
Old Feb 21, 2009
gearbox is probably right you blew a fuse
Old Feb 22, 2009
Amps's Avatar
Cheers yeah, I guess I did had some1 else look at it, and noticed the mechanic had put in the wrong fuses in.
Cheers guys.
Old Feb 22, 2009
hah always make sure you disconnect negative terminals before messing with wires. You can mess things up and blow fuses and bulbs
MyCivic
Electrical
Oct 28, 2021 11:06 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
werdnahall
May 17, 2015 11:37 AM
davidarenberg
May 16, 2015 08:45 AM
klam
Nov 16, 2001 03:36 PM
