good brand of fuel injector
Old Nov 20, 2017
kagan21's Avatar
kagan21 is an unknown quantity at this point
hey guys like the title says i need to replace the fuel injectors on the car since the old ones are leaking. im thinking about re-manufactured from rockauto which they have:
autoline
GB remanufacturing
beck/arnley
so any suggestions? or just buy new ones.
Old Nov 20, 2017
Wankenstein's Avatar
Re: good brand of fuel injector
autoline
GB remanufacturing
beck/arnley
How about OE or OEM from junkyard..probably $5-$10 each, exact fit and specifications too.
Old Nov 20, 2017
Stock Honda.
Are your actual injectors leaking, or just the O ring seals? You can buy fresh injector O rings dirt cheap.
Old Nov 21, 2017
oneheadlight's Avatar
oneheadlight is an unknown quantity at this point
Cool Re: good brand of fuel injector
autoline
GB remanufacturing
beck/arnley
DO NOT waste your time on remanufactured fuel injectors! DO NOT WASTE YOUR TIME!! Yes I am repeating myself!
I went down this path before with my 96 civic.. You will not like the results! All these companies do is clean up old injectors that were someone else's problems. Now they'll be yours! I do not care what they claim, I had this junk, you do not want it!
If yours are leaking externally then it might just be you need to replace the o-rings. That's easy.. But if they're dropping fuel into the intake then replacement is your only option. The body is sealed and there's no way to replace the internal o-rings.
Yes it's true Honda genuine parts would be nice, but in case you don't have around $200 for each injector.. SMP is the brand I bought, hey I am not a millionaire, thanks Honda. Standard Motor Products is SMP, they also go by the name Intermotor. SMP is the parent company. The ones I got are brand new, manufactured by SMP in USA, south carolina I think it is.
I've had these injectors since August and so far they're working well. I do not know how long they'll last, but I did not have $800 to drop since Honda thinks their injectors are pure gold. So we'll see how long I'll get..
