Civic 98 EXi Automatic Missing
Old Feb 16, 2017
swaqas16's Avatar
The Car We Drive Say Alot About Us..
swaqas16 is an unknown quantity at this point
Arrow Civic 98 EXi Automatic Missing
Hi,
Nowadays I am facing an issue with my Civic 1998 having D15z5 engine.
It does missing on low RPMs and when I turned on AC,the throttle response is very delayed like it takes 4 to 5 seconds to pick RPM with little vibtration.
I have changed Fuel filter,spark plugs,air filter,engine oil but problem is still there.
What is the possible solution for this problem?
Could it be a Timing belt problem?
Old Feb 17, 2017
Re: Civic 98 EXi Automatic Missing
Check engine light on?
Fault codes?
Cylinder contribution check?
Compression test?
Spark timing check? (if dramatically incorrect, inspect cam-crank relationship (timing belt jump))
Plug wires?
Plug wires incorrectly ordered around the distributor cap? (Firing order: 1-3-4-2)
