Driver's Side Window Missing Rubber Track
Old Jun 30, 2015
Wankenstein's Avatar
1998 Civic EX stock purchased six months ago.
Replaced regulator a couple months ago and noticed front (facing) lower window track/guide is devoid of rubber. WIndow/motor working fine so far but, fear that it might bind. Does that track have to be pulled out to replace rubber or is there an easier solution?
I thought about buying felt and gluing it in without removing the track.
Old Jun 30, 2015
Re: Driver's Side Window Missing Rubber Track
Run channel seal (vertical), or the horizontal strips at the top of the door panel?
Old Jun 30, 2015
The vertical Run Channel Seal.
Should I go junkyard use or new? And if new does it have to be OEM or other?
http://www.autopartswarehouse.com/sk...810331&c_net=g
Old Jun 30, 2015
Used or new??
If it's torn off and missing, I'm sure anything would be better than nothing..
The correct weatherstrip would tuck into the metal channels and stay.
I'd hose the entire weatherstrip liberally in spray silicone lubricant to ease installation.
If you get junkyard be sure to wash the felt surfaces with hot soapy water...dirt embedded in the seals makes the glass drag.
Old Jun 30, 2015
Used or new??
Thank you again..Ezone.
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
timpan
May 18, 2015 07:06 AM
mwwhonda
Nov 7, 2001 07:24 PM
EXWisdom
Nov 5, 2001 10:24 PM
