97 civic EX dies in gear
Old Mar 22, 2015
hondacivicguy30's Avatar
hondacivicguy30 is an unknown quantity at this point
Hey guys. I have a 97 civic ex with 199,XXX miles automatic trans. When I first got the car I noticed the idle was very low to the point the car would just die. My mechanic said to replace the IACV. So I replaced the IACV twice (the first one I got was default) and that fixed the original problem but then I got a new problem. When I turn the car the on car idles around 1200-1500 rpms in park, but as the car warms up, it eventually dies, about 15 minutes. However, as soon as I put the car in drive or reverse, the rpms die immediately, and unless I give it gas, it dies completely after about 10 seconds. I have done research and I cant figure out the problem. If anyone could help me I would really appreciate it.
Old Mar 23, 2015
fewall11b's Avatar
fewall11b will become famous soon enough
Re: 97 civic EX dies in gear
Check the throttle body position sensor. Use a multimeter to check the volts at idle to see if they are within tolerance of the service manual.
Old Mar 23, 2015
After replacing the valve, did you do the idle relearn?
Old Mar 25, 2015
I disconnected the battery and after reconnecting I drove it let it run for 15 minutes then drove it around the block. When I got home it died and has been acting up ever since.
Old Mar 25, 2015
I don't have a multimeter to check but do you think autozone would be able to do that for me? I only have bare minimum for tools, socket set, screw drivers, etc just enough to get by.
Old Mar 25, 2015
fewall11b's Avatar
I'm not sure, but you can call and ask. I know they have some stuff for rent and other things like a scan tool you can use at the store.
Old Mar 25, 2015
Alright I'll call. Thanks bud.
EC3
Apr 22, 2015 07:55 PM
twtron
Apr 17, 2015 12:09 AM
McD
Apr 16, 2015 10:46 AM
xtremedreams
Bolt-on Engine Performance
Nov 14, 2001 12:30 PM
Russps
Nov 8, 2001 02:00 AM
