code p0335 CKP sensor
All, I have this code plus the fact that I beat up the connector pretty bad when replacing the distributor. So, I am thinking that I need to replace the connector, but junkyards seem to be the only source and haven't found one yet. Car runs OK except when you try to accelerate quickly, then it falters momentarily at gear change. It also seems to change to 3rd gear a bit late, after engine is revving to 3500. What is your advice? Thanks
Re: code p0335 CKP sensor
Aftermarket reman distributors are crap. You might try a couple others before hacking into your wiring harness?
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Apr 17, 2025 12:24 AM
beantech
Jun 15, 2015 07:09 PM
juror
Jun 9, 2015 02:15 PM
juror
May 26, 2015 06:35 PM
