2000 honda civic power locks won't work
Old Aug 5, 2014
Kate_86's Avatar
Kate_86 is an unknown quantity at this point
I recently purchased a 2000 honda civic sedan lx. I have replaced the bad fuse under the hood for the power locks. The back door locks will unlock but they won't lock. The front passenger door will only make a noise as if it is working but it doesn't lock or unlock. And the drivers door doesn't make any noise and does not work at all.
Am I needing just all new actuators?
Thanks
Old Aug 5, 2014
dailycommuter's Avatar
dailycommuter is an unknown quantity at this point
Re: 2000 honda civic power locks won't work
Thanks
I have the same issue.
A click sound and no movement means that the fuses are fine and the problem might be with the actuators or even the driver's main control switch.
Old Aug 9, 2014
nsxvtec's Avatar
nsxvtec will become famous soon enough
Actuators are a known common issue. They are easily replaced (new) or can be refurbished with the right parts.
Old Aug 9, 2014
Phatmatt's Avatar
Phatmatt is an unknown quantity at this point
Is there a how to to refurbish them? Or a way to test them?
I have the same problem.
Old Aug 9, 2014
nsxvtec's Avatar
Many post regarding refurbish or replacing actuators. Please do a search on the topic.
Places here TO area will do the R & R. If you are handy with tools and can help yourself you can easily replace them. For the adventurous inquisitive Rebuilds are also quite easy. Search Honda Civic Door Lock Actuators.
Old Mar 13, 2015
Bigrube's Avatar
Bigrube
Bigrube is an unknown quantity at this point
2000 civic has no sound when using power lock button. any thoughts, anyone
Old Mar 13, 2015
poole307's Avatar
poole307 is an unknown quantity at this point
I had similar issues on my 98 civic i took my door panel off and lubricated the actuator and all the places that the locking and unlocking rods came in contact with and solved my issue its worth taking a look at to save money.
Old Sep 30, 2015
MamaBear2015's Avatar
MamaBear2015 is an unknown quantity at this point
I'm glad that I figured out how to search the generational threads, instead of just posting anew, and found this.
We just bought a 2000 LX and the front passenger side door is sticking, and it seems like an old solenoid that may have gotten dirty over the years. Now all I have to do is figure how to take the door apart ( video somewhere - usually YouTube ) and get the WD40 ( cures almost anything ).
Oh wait. Now I'm thinking maybe silicone spray instead? Not to hurt any plastic?
And instead of removing the door panel - spray through a straw, straight down the lock button hole?
Ahah! Looked at a can of silicone spray that I have. Says it even extends the life of plastic. Yeah!...
roverben
Jan 21, 2019 05:16 PM
bsmiley
Apr 27, 2015 01:27 PM
jessicakaybby
Apr 20, 2015 12:11 PM
Killagi
Apr 12, 2015 10:42 AM
liljoe
Nov 4, 2001 01:27 PM
