timing idle problem
Old Jul 12, 2014
kevkreck1960's Avatar
kevkreck1960 is an unknown quantity at this point
timing idle problem
hi, i have a 2000 honda civic vp just installled a distributor in it and
cant get it to time,, spiking up down low idle in park turned distributor as far down as the slots allow,, when air is on it seems to even out but without spikes like crazy.. took it to garage they couldnt get it timed eather! origionaly found a a bad icm replaced it and couldnt get the idle set
so purchased the new distrib.. cant get it to set eather. any help would be deeply appreciated
Old Jul 12, 2014
Re: timing idle problem
Jumper the SCS connector to put timing control into base mode.
Old Jul 13, 2014
did the jumper,, set no 1 piston to top position turned dist to16% tdc ,, still out of time
anything else that could cause this? ditributor is good.
Old Jul 13, 2014
panhandler62's Avatar
panhandler62 is an unknown quantity at this point
Have you checked the wires and plugs? My daughter's 97 has a dead cylinder (not ignition related in her case) and it displays symptoms like that -- runs smooth under partial throttle (which turning on the AC provides), idles poorly.
Just a shot in the dark.
Hooking up a scanner will tell you where the timing is at.
Old Jul 13, 2014
Wait a sec....You aren't using a timing light?
How did the original distributor get timed?
Crummy reman dist, try again?
Old Jul 13, 2014
Is the cam timing correct?
sharp66
31
Jun 12, 2022 08:45 AM
TXcivic2001ex
Air Conditioning
23
Jul 20, 2020 07:27 AM
mikemc422
Aug 9, 2018 05:41 PM
crowtoo
May 11, 2015 06:50 PM
jakeconnor
May 5, 2015 07:30 AM
