'98 HX 5psd P0301 Primarily...out of nowhere
Old Mar 9, 2014
longdrive352's Avatar
longdrive352 is an unknown quantity at this point
1998 Civic Hx 183k. All stock. No recent work done. Noticed a change in mpg on most recent fillup (beginning of last week), and a little hesitation it seemed at times. I almost had myself convinced the clutch might be starting to slip. There were no hiccups or rough running conditions at all.
That changed Friday on my way home from work. 65 miles each way. I was 30 miles into the ride home when I started experiencing the P0301 condition. I run a scanguage II constantly - just so I can see when the engine goes into lean burn. However, that was another thing I noted in the days prior to this problem. I couldn't feel the engine going into lean burn, and the indicator wasn't showing that it was in LB mode....at all. Now, I didn't watch this constantly, but when my last mpg calculation showed a drop (5mpg or so), I started watching, and noted that it didnt' seem to be dropping in.
I was under a quarter of a tank on Friday night...so I filled it up with fresh gas on the way home. Saturday I changed the fuel filter first because I had recently filled up at a service station I don't frequent, and started thinking maybe I got bad gas ??
Anyway, changed the fuel filter, changed the distributor cap and rotor, and no improvement yet.
I'm just not sure where to go next.
Operating on the hunch that the gas may have been an issue, I was thinking about pulling the pump and getting a look at the screen and the actual tank contents. That still leaves me with what is causing the codes now....eventually branched out to include 0300, 0301, 0302, and 0304...as well as 0000.
After replacing those parts yesterday and letting it run for a little while, I'm just showing P0301 again, nothing else.
Sorry to be so long winded. Thanks for any suggestions.
JP
Old Mar 9, 2014
Poopies's Avatar
Super Moderator
Re: '98 HX 5psd P0301 Primarily...out of nowhere
How old is the battery? The spark plugs?
Old Mar 9, 2014
The battery is less than a year old. To be honest, I haven't even looked at the plugs yet. I go do that now.
Old Mar 9, 2014
Poopies's Avatar
Super Moderator
Let us know what you find! Pics if possible!
Old Mar 9, 2014
I pulled all four plugs and regapped them. The plug from cylinder #1 does look different than the others, but it doesn't look "terrible". They were ALL significantly out of gap spec tho. .039-.043. I gapped them all to .041 and ran the engine. The misfiring is still there...as bad as before. This time I got codes P0300, P0301, an P0302 like on the final leg of my drive home Friday.
Here's the pic.
Old Mar 9, 2014
Poopies's Avatar
Super Moderator
Hmm, those plugs are definitely used but you're right, they're not bad at all. How about the injectors? Have you tried cleaning them out? You can try putting some cleaner in your tank first and hopefully it'll do the trick in time.
Brandon Vlasak
Jul 25, 2015 07:25 PM
oreo465
Sep 16, 2014 05:14 PM
mrohitredd
33
Aug 27, 2014 10:59 PM
BigAwesome
Jun 14, 2013 03:12 PM
laughatdanger
Mar 17, 2011 04:25 PM
