Please help
Please help
I basically was driving on the freeway and started hearing loud clanks when I hit the gas. Pulled off and it was making the loud mechanical noise clank. I added two quarts of oil and drove to the shop. Basically I had him drain the oil to se if there was a leak and he said he drained it and there was only the two quarts of oil I had put in. So I was driving the car without oil and now there is a clicking noise when i rev the engine.
What could my issues be?
Thank you
Thank you
Re: Please help
Re: Please help
Rod knock or any bottom end bearing noise.
Re: Please help
You let your engine run out of oil.
If it now hammers loud enough for people 2 lanes over to stare in disbelief, the next cool trick it could do is scatter parts all over the road.
Congratulations, you get to pay "the tax".
Re: Please help
Much like being a "little bit pregnant"?
If it sounds like a threshing machine now instead of the sewing machine it used to sound like...... Guess what!
Re: Please help
Something got warped inside the engine due to all the friction heat it generated from the lack of oil. You still might be able to get something for it as a fixer-upper if the body and interior are still decent...
Re: Please help
Typical bearing failure after oil starvation
The crank journal and whatever else is hammering will be gouged and worn accordingly.
EDIT: And the trashed metal is likely now circulated all throughout the rest of the engine, lodged in every part of the oiling system, top to bottom.
Almost anything can be fixed.
Not for free.
A 'drop in' used engine is usually the cheapest option.
i cant fix it?
Not for free.
