misfire code
misfire code
finailly found the reason for misfire code .the fuel injector clips were a little loose ,they made a click sound , but had to be wiggled in a little more.... off went the check eng. light after weeks of hell and money wasted on pulgs.wires.cap.ect. the dealership could not find this one ,with all their dionostic machines,, they just threw parts at it
Re: misfire code
There isn't any machine that can diagnose a problem.
They are only tools.
It's all up to a human to use the tools effectively.
(It helps when the human doing the work has more brain cells than a head of lettuce.)
It helps if the problem is actually acting up when someone checks out the car. Intermittent and random can be awfully damned tough to find.
Re: misfire code
Hey so two days ago, i changed one of the injectors, and now my car is misfiring on all cylinders. But Im not missing any vacuum hoses lose or disconnected.
Spark plugs work as well, but my misfires only show when the car is under load. Do you think its injector'
s connection?
Re: misfire code
s connection?
Re: misfire code
Partial miss or weak cylinder contribution instead of dead miss would normally be something other than ignition.
Also, what I see as normal stuff in my world may not be the same as your world. Customers here aren't going to have their injector connectors off 3 dozen times in 3 months like some of the kids would, so injector wiring is pretty far down the list for me..
If you think it's injector connections, you should probably be able to wiggle each plug and cause the miss to come and go as the wires make or break their connections.
Another thought: Do all 4 injectors have the same flow rates? Not just ratings, but actual flow?
One that is way fatter or leaner than the rest can really confuse the computer.
Got the big seals on the bottom of the injectors all still in the right places, none slipped making vacuum leaks?
Civic15
18
Sep 19, 2017 07:48 PM
Green02civic
Jul 27, 2015 10:48 PM
NROD315
Jul 21, 2015 07:46 PM
