civic backfire
Old Apr 9, 2013
MAXX94's Avatar
MAXX94 is an unknown quantity at this point
civic backfire
so i just got a 94 civic ex coupe and it seems to backfire. has a d16z6 engine but it was barley put in. can some one tell me what is causing the backfire?
Old Apr 10, 2013
Gunner's Avatar
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Gunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to all
Re: civic backfire
What does this mean?
backfire could be a lot of things, can you expand a little?
<---is it on?
Old Apr 10, 2013
MAXX94's Avatar
Re: civic backfire
The original motor(d16z6) that was in it started messin up, so I found a used motor(d16z6) and put it in!
I put the car on neutral and step on the gas and heard the backfire!
Old Apr 11, 2013
Gunner's Avatar
Re: civic backfire
Does it backfire when driving down the road, does it do it a lot, a little, when was the last time you check your spark plugs?
Old Apr 11, 2013
MAXX94's Avatar
Re: civic backfire
i really cant hear anything when im in the car
Old Apr 12, 2013
Gunner's Avatar
Re: civic backfire
what about your check engine light -->
If it only does it in neutral the it might be semi normal since when you rev the car in neutral the cylinders are being loaded with fuel. When the rpm comes down the exhaust valve causes the excess fuel to burn causing the backfire.
Otherwise it may be time for a tune up...(vacume leak,timing..or 100 other things)
so if it drives smooth, and you cant hear it in the car then maybe things are good...
McD
Apr 16, 2015 10:46 AM
locozoko
Apr 6, 2002 09:00 PM
Cilvic
Nov 15, 2001 04:54 PM
silvervtec01
Nov 4, 2001 06:56 PM
WeRkX
Nov 1, 2001 10:33 PM
