Civic lx trans problem
Old Apr 1, 2013
Bbqb4racin's Avatar
Bbqb4racin is an unknown quantity at this point
Hey guys, I've been mulling around for awhile looking for an answer and just can't find it. So I figure if somebody knows the answer it will be you guys.
I have a 1996 civic lx 1.6l a/t. When I put it into D it drives fine in first but won't shift to second. If I click it down to 2nd it goes into 2nd. But it won't go into third no matter what. It doesn't slip or anything, it just won't go in. Any ideas? Tps possibly? I'm hoping for some feedback from somebody who had this happen or who is familiar with it. It has 99000 miles. Thanks!
Old Apr 8, 2013
danwat12345's Avatar
danwat12345 has a spectacular aura aboutdanwat12345 has a spectacular aura about
Re: Civic lx trans problem
step 1 is to scan the computer for trouble codes/monitors.
Hopefully it is something as simple as needing to replace the solenoids at the top of the transmission.
From this thread it could maybe have to do with a dirty throttle body
https://www.civicforums.com/forums/1...-slippage.html
Or wiring with the solenoids;
https://www.civicforums.com/forums/2...-1st-gear.html
a TSB
http://ww2.justanswer.com/uploads/cr...0_bulletin.pdf
Old Apr 14, 2013
Bbqb4racin's Avatar
It wasn't throwing any trans codes. I pulled the 7.5 amp fuses from a thread I saw on here and that fixed the problem. Thank you for your input.
Xuhme
21
Aug 7, 2023 03:40 PM
jackoncruzpr
Apr 16, 2015 12:29 PM
dooner24
Apr 14, 2015 07:51 PM
Russps
Nov 8, 2001 02:00 AM
NoToRiOuSxPiNoY
Bolt-on Engine Performance
Nov 7, 2001 11:19 PM
