97 d16y8 timing issue
Old Oct 31, 2012
JNVA17's Avatar
JNVA17 is an unknown quantity at this point
I have a 97 d16y8 and it won't rev over 6000 rpm first in 1st gear now all the way through 5. check engine light came on. It read ignition timing and miss fires. Could I have jumped timing bc my timing belt is a little loose?? How do I set all my timing? Is there a way to set my oil pump timing?
Old Nov 1, 2012
Re: 97 d16y8 timing issue
Really? What code is that??
May or may not be related to any codes. Misfire can kill a cat.
If there is nothing related to it in the code fix, I may check backpressure. Really depends on how it acts and what I think during testing.
If it really is loose, it may be time to replace it.
You may want to consult a real shop manual.
Nope.
HTH
Old Nov 1, 2012
JNVA17's Avatar
What do you mean by back pressure? And I don't remember the code I cleared them they haven't come back up. but a code for o2 sensor is still up. Any relation?
Old Nov 1, 2012
Backpressure: as in clogged exhaust/clogged cat.
O2 sensor code: What is the code number?
Old Nov 3, 2012
JNVA17's Avatar
I don't remember. But I remember some a/d heat sensor code?? I did some research the sensor wouldn't let my motor rev past 6krpm to keep my motor temp low because I have a leak in my radiator and I had very low coolant which we all know keeps the motor temp down
Old Nov 3, 2012
A/F (Air/Fuel ratio) Sensor Heater Circuit?
I don't think US cars got an A/F sensor. It's an O2 sensor in the parts catalog.
I think you have made more than one wrong assumption here. I count at least 3.
At least one of those wrong assumptions will be catastrophic and expensive if ignored (if not already too late).
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
intensity
May 12, 2015 10:43 PM
Supramk3
May 11, 2015 07:55 PM
crowtoo
May 11, 2015 06:50 PM
civic_gt
Apr 19, 2015 08:15 AM
