'98 civic dx speedometer problem
Old Jun 18, 2012
JEFFROETIP's Avatar
JEFFROETIP is an unknown quantity at this point
Question '98 civic dx speedometer problem
I was having issues with my speedometer jumping for a while & then it would just stop. Sometimes it would show me going 90 mph even though i was only going 60 or so. Eventually the needle flipped all the way around to the other side of zero where there is the little peg there to stop it going any futher.
It would work here and there, and when it wasn't working at all the odometer would not work either. I replaced the speed sensor and the odometer is working, however the speedometer is stuck around on the wrong side. I have pulled everything out of the dash, and tried to manually move the needle but it will not work. It tries to work from the wrong side though. Any suggestions?
Old Jun 18, 2012
Re: '98 civic dx speedometer problem
Just guessing here, if you can't make the needle go back to where it started and work, it sounds like you will need a new speedometer.
Unless you can send it to a speedo shop for repair.
Old Jun 21, 2012
JEFFROETIP's Avatar
I found a speedometer cluster on ebay & it works perfectly now thanks!
Xuhme
21
Aug 7, 2023 03:40 PM
dragonsblood
Apr 27, 2015 12:28 PM
smmahan
Apr 15, 2015 08:17 PM
dooner24
Apr 14, 2015 07:51 PM
NoToRiOuSxPiNoY
Bolt-on Engine Performance
Nov 7, 2001 11:19 PM
