2000 honda civic ex car boggs down and stalls while driving
Old Sep 7, 2011
nickrolando's Avatar
nickrolando is an unknown quantity at this point
So I was on my 30 minute commute to my job this morning and i felt my car made a jerk then I put it in 1st gear b/c of traffic and i moved a little bit and when i hit the gas the engine bogged down and i tried hitting gas again same thing until it stalled
Tried to start it back up, the starter kept turning over and finally it started and i tried to move and the same thing kept happening until it stalled again.
Got it towed off the parkway
What is the first idea's as to what it probably is?
Old Sep 7, 2011
Re: 2000 honda civic ex car boggs down and stalls while driving
possibly the fuel pump died? or timing belt skipped a tooth. its hard to say for sure because so many things can cause the car to drive badly.
Old Sep 7, 2011
Its at the mechanic's now. I'm hoping its a fuel pump. He said if it is $175.00 for the fuel pump and $80.00 to install it.
Don't think its the timing chain because its running horrible still.
Do you mean the fuel pump may be DIEING not DEAD yet?
Old Sep 7, 2011
yeah you might just have really low fuel pressure. im sure he will check the pressure and go from there.
Old Sep 8, 2011
Just spoke to the mechanic, hes saying for w.e. reason, he does not think its the fuel pump. he said hes in the middle of cleaning the distributor n took cap off n **** and is gonna take it for a ride soon n see how its running. idk tho i feel like it would of been the fuel pump/filter?
Old Sep 9, 2011
So 40 dollars later, all it was, happened to be an electrical connector somewhere in the distributor cap and it was loose shaking on the connection, so they fix it and made sure it would stay on, been good every since for the past 24 hours!
Old Sep 9, 2011
TreeFortRichard's Avatar
TreeFortRichard can only hope to improve
damn...I was just going to suggest this. I have a 99 civic ex and had the same problem. It turned out that the 4 wires connecting from the distributor to the spark plugs had corroded/worn out and were letting moisture in. Whenever it was wet out I lost power and the engine was essentially misfiring. If you were going fast enough you could power through it, but once you slow down it dies..
Old Mar 30, 2014
xr2flight's Avatar
xr2flight is an unknown quantity at this point
Hi All,
I'm brand new to this forum and this sounds exactly like what happened to me this morning. I'm driving a 2004 coupe ex. I don't see any further responses though. Is there any update or advice out there? I'm still reading through the results of my search and I'm hopeful that I'll find something helpful.
Thanks in advance! Meantime, I'll have a look at the distributor cap and its connects.
After reading through, there are many suggestions and things to look into. So I just tried starting up the vehicle to give the most info I can about the vehicle. The car doesn't seem to have any issue with starting, but just a few seconds and it dies.
I
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
jessicakaybby
Apr 20, 2015 12:11 PM
chgofirefighter
Apr 18, 2015 08:08 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
liljoe
Nov 4, 2001 01:27 PM
