Transmission Mistake; Wrong Bolts
Old Jul 29, 2011
bft's Avatar
bft
bft is an unknown quantity at this point
Ok I started out to save myself some money and I think I may have hurt myself instead. I'm replacing the engine in the wife's Honda. I got the engine and transmission removed and was in the process of separating the pair. Some how when I was working to late a few weeks ago I removed two bolts that I had no reason to remove. I really don't know what I was thinking at the time they're no where near where I was working. They are in the top of the transmission and are hollow I guess transmission fluid pumps through them. Neither of the bolts will fit back into there holes. Something I'm guessing inside has shifted. I did some googling and could not find a rebuild manual or an exploded diagram. I came here out of desperation hoping someone here has transmission experience. I'm attaching pics the problem bolts and there location. If anyone is able to point my towards some information that might yield a solution I would be very grateful. Thanks for reading this.
ID:	81438   Click image for larger version
ID:	81439   Click image for larger version
ID:	81440   Click image for larger version
ID:	81441   Click image for larger version
ID:	81443   Click image for larger version
ID:	81444   Click image for larger version
ID:	81445   Click image for larger version
ID:	81446   Click image for larger version
Old Jul 29, 2011
MelJ's Avatar
Trance Addict
Re: Transmission Mistake; Wrong Bolts
It looks like one of the bolts has a feed hole or holes drilled into them. It's hard to say since I'm on my phone viewing the page. That's really odd that they won't go back into their respective holes. I'll try and look once I get to my pc some time tonight.
Old Jul 30, 2011
lazlong's Avatar
They're "line bolts". They hold the ATF cooler lines to the tranny and allow flow of the ATF. The manual just says to remove when taking apart and to just install when re-assembling.
Old Jul 30, 2011
bft's Avatar
bft
Thank-you I had to take a 3 week break after pulling the engine and I forgot those are the for the transmission line. Nothing wrong than Thanks. Something very similar happened to me on the lower end of a boat a few months back so see this brought be back to a worse time. Solved
GolNat
Suspension DIY
May 12, 2022 06:49 AM
Skillzzz
Jun 26, 2015 09:46 PM
wholt0
Transmission
Jun 11, 2015 11:15 PM
bo_red
Transmission
May 3, 2015 09:14 PM
artychris
Jan 6, 2002 09:27 PM
