97 Civic Speedo Problem
Old Jun 14, 2011
Charbo's Avatar
Charbo is an unknown quantity at this point
I just bought a 97 Civic LX, it has a B20B it. The speedometer is jumpy and over 2500 rpm it just goes up and up. Under 2500 rpm it seems to be accurate. What could be causing this?
Old Jun 15, 2011
Charbo's Avatar
Re: 97 Civic Speedo Problem
Ok, so it jumps around pretty much all the time and the only time it seems to be accurate is when I am not giving it gas.
Old Jun 15, 2011
Charbo's Avatar
I read on another forum that it could be a grounding issue, because at night my lights will get dimmer and brighter randomly. What all do I need to replace to make sure everything is getting a good ground? What wires should I check to make sure they arent grounding out or anything? This is the first car ive had with an electric speedometer so I dont know what to look for.
Old Jun 16, 2011
Charbo's Avatar
Well I got it fixed. The wires for the speed sensor were just sitting in the hole so I taped them for now because the parts store was closed.
Xuhme
21
Aug 7, 2023 03:40 PM
Braun
Apr 23, 2015 09:03 PM
dooner24
Apr 14, 2015 07:51 PM
NoToRiOuSxPiNoY
Bolt-on Engine Performance
Nov 7, 2001 11:19 PM
